Need help, dont know, whats wrong with my pc!
thapoop
33
Hello!
I have been playing CS:GO (and other games) for a long time and from time to time, the fps of most of the games just reduce and I sometimes found a fix for it...
But now, i dont know what to do.
Here is everything I did (If I remember everything):
Defragging
Installing (and re-installing) the latest drivers for every component
Updating all important updates from Windows Update
Anti-Virus Progs did not find any malware
Buy new components (CPU, GPU, RAM, Water Cooling)
Using several "cleaning" and "tuning" tools (CCleaner, TuneUp)
and last but not least: Full Format of the HDD
I'm at the end of my freaking nerves and I would be glad, If some of you guys out there have a solution for it.
My PC Specs:
Intel Core 2 Extreme Q6850 3ghz * 4
AMD Radeon HD 6950 2GB
ASUS P5N32E-SLI
6GB RAM
500 GB HDD
Corsair VX 550 Watt PSU
If I forgot something, then please tell me!
Thanks in advance!
I would first try to overclock the cpu you have now.
About those two builds,for now neither.There's too little known about the psu's and with pc that use as much power as these do you want a good psu in it.
From the second amd build can i not even see which motherboard is used.Another minus for that one.
Sorry for the late reply.
Ok gonna try it.
