T tcmr Jun 19, 2021 6 1 15 Jun 19, 2021 #1 I would like help building a PC that will run a somewhat intensive charting website, (exocharts) on dual 50" Hisense TV's. This will run linux. I don't need the fastest possible, but I cannot have lag. Thank you, Jim
Solution 4745454b Jun 20, 2021 Newegg has one, but the cheapest one I see is almost $700. The MSRP is $280. 3x as much as it should cost.
4745454b Retired Mod Apr 29, 2006 29,244 449 93,590 Jun 20, 2021 #2 Budget? Any decent card is selling for many times it's MSRP. You're going to have to buy the best too expensive card you can afford. Upvote 0 Downvote
David0ne86 Prominent Mar 11, 2021 423 111 440 Jun 20, 2021 #3 I would imagine exocharts being more cpu heavy rather than gpu? So you could get away with a 1050 ti. Upvote 0 Downvote
T tcmr Jun 19, 2021 6 1 15 Jun 20, 2021 #4 AMD only due to ease of linux support. I was told 6gb memory is needed. How about a 5600xt? I see Newegg has one available. Upvote 0 Downvote
David0ne86 Prominent Mar 11, 2021 423 111 440 Jun 20, 2021 #5 should be plenty enough. Upvote 0 Downvote
4745454b Retired Mod Apr 29, 2006 29,244 449 93,590 Jun 20, 2021 Solution #7 Newegg has one, but the cheapest one I see is almost $700. The MSRP is $280. 3x as much as it should cost. Upvote 0 Downvote Solution
