need help finding a RNG method
G
Guest
Guest
Archived from groups: rec.games.roguelike.development (More info?)
Hi im kinda getting back into the c++ scene after about a 3 year period
away from it and would appreciate some input on how to as easily as
possible impliment random number generation in c++. Please note i
havent coded in a long period of time and may need to have things
explained in a almost Dr. Suess way.
G
Guest
Guest
The Mersenne twister is a very good algorithm for roguelikes. not
random enough for encryptions and other applications requiring very
random numbers, but it should be fine for a roguelike.
http://www.math.sci.hiroshima-u.ac.jp/~m-mat/MT/emt.html
Just take init_genrand(unsigned long s) and feed it the time when you
start the program, and use genrand_int32(void) % x to get a random
number between 0 and x. type cast it if you want an int. Happy coding!
G
Guest
Guest
"Catyalyst" <catalyst5505@gmail.com> writes:
In C++? Boost:
<http://www.boost.org>
Here's an example from their docs:
#include <boost/random.hpp>
boost::mt19937 rng; // produces randomness out of thin air
// see pseudo-random number generators
boost::uniform_int<> six(1,6) // distribution that maps to 1..6
// see random number distributions
boost::variate_generator<boost::mt19937&, boost::uniform_int<> >
die(rng, six); // glues randomness with mapping
int x = die(); // simulate rolling a die
One minor oddity about the Boost RNG approach is that there are two parts you
have to deal with - a generator and a distribution. You can choose one of each
to produce exactly the kind of RNG you want.
There are many generators - The above uses Marsenne Twister, there are also
Lagged Fibonacci, Linear Congruential, and a bunch of others with names only
a math guru could understand. ;-)
There are many distributions too. The above Uniform Integer returns a non-
weighted distribution over a range of integers. There are distributions that
simulate a coin flip, points on a sphere, etc.
sherm--
Cocoa programming in Perl: http://camelbones.sourceforge.net
Hire me! My resume: http://www.dot-app.org
G
Guest
Guest
At 14 Sep 2005 08:06:37 -0700,
http://www-personal.engin.umich.edu/~wagnerr/MersenneTwister.html
Note that you can't possibly write a random number generator without
using some kind of hardware source of entropy... The best you can do
is to make a pseudorandom number generator ;)
Radomir `The Sheep' Dopieralski @**@_
(Oo) 3 Eh?
. . . ..v.vVvVVvVvv.v.. .
G
Guest
Guest
Many people in rgrd seem to advocate the Mersenne Twister, a remarkably
fast and potent RNG. I decided the code was too bulky for me to be
comfortable with, so I'm using the code that you can see as "rng.c" in
the Dungeon Bash source code, which I cribbed from an archived Usenet
post someone pointed to in rgrd a while back. It seems to provide Good
Enough results, and has quite a simple algorithm.
"main.c" in the Dungeon Bash source code has a few basic wrappers for
the RNG functions.
Martin Read - my opinions are my own. share them if you wish.
\_\/_/ http://www.chiark.greenend.org.uk/~mpread/dungeonbash/
\ / the sweeney's doing ninety cos they've got the word to go they've got a
\/ bunch of villains in a shed up at Heathrow -- Squeeze, "Cool For Cats"
G
Guest
Guest
hey thanks every one i really apprecaite all the help you all gave me
^_^ ive downloaded the boost libraries and might try to incorporate the
RNG there as i dont plan to get overly complicated to begin with, its
been forever since ive used the language just need to get my feet wet
again.
G
Guest
Guest
> Please note I haven't coded in a long period of time and may
> need to have things explained in a almost Dr. Suess way.
In the town of C you can learn many things,
New ways to make numbers and new ways to make pings.
Random numbers are not very computational.
You need specialized hardware for that.
Try a routine like Linear Congruential.
It's like pulling a rabbit out of your hat.
Some are quite simple and others most sinister.
Lagged Fibonacci? Perhaps Marsenne Twister?
There are many pseudo random number routines in the land.
Many of them with names only a math guru could understand.
While you're searching for the code that will work,
be careful what you wish for, since you might find a jerk. :)
TAZ (Yeah, it's a slow day at work.)
G
Guest
Guest
I might check out that.. I'm using rand() at the moment. Some
people say it's bad, but I can't figure out why:)
G
Guest
Guest
On MSVC, RAND_MAX is 32768.
I shouldn't need to say more.
I was using rand() on the theory that "surely every compiler vendor
would have got this right by now" but the Windows version of POWDER had
*very* unusual item distributions until I threw it out. I was
foolishly assuming that RAND_MAX would be INT_MAX. Rather than change
that assumption, I threw out rand().
Jeff Lait
(POWDER: http://www.zincland.com/powder)
G
Guest
Guest
On 14 Sep 2005 08:06:37 -0700, "Catyalyst" <catalyst5505@gmail.com>
i use a MAQR model, so the only state I need is a 32bit signed
integer... and its implemented in about 10 lines of code.
- Stu : Email via http://public.xdi.org/=stu
G
Guest
Guest
Well, I don't know what that means:)
Isn't that good, when random is unusual and doesn't show any
repeating behaviour?:)
G
Guest
Guest
Lets say you are lazy and use % to get your random values.
// Returns a value from [0...n), handling negative n
// and n == 0 so you don't crash with division by
// zero.
int
rand_choice(int n)
if (n < 0)
return -rand_choice(-n);
if (n <= 1)
return 0;
return rand() % n;
Then you do something crazy like:
if (rand_choice(100000) > 50000)
Do special thing
If RAND_MAX is 32767, rand_choice can never return a value higher than
32767, and that special thing will never be done.
I ran into this because I was building a cumalative probability table
to select from with the average weighting being 100*100, or 10,000.
Not when out of the hundred possible items, only ten ever get
generated.
Jeff Lait
G
Guest
Guest
> Do special thing
Can't you change that to (rand_choice(100)>50).
G
Guest
Guest
> > Do special thing
No you cannot.
The test I wrote will pass for numbers 50,001 to 99,999. It will fail
for numbers 0 to 50,000. The probability of passing is thus 49,999 in
100,000. That probability is not the same as your example, which is 49
in 100.
49% != 49.999%. Your attack on a mere technicality has failed. Do not
pass go and do not collect 200 pedant points. :>
Jeff Lait
G
Guest
Guest
"Krice" <paulkp@mbnet.fi> writes:
If you call rand() you get a number between 0 and RAND_MAX (or
RAND_MAX-1, perhaps).
Most of the time, RAND_MAX is 2**31 (ish).
Effects of this:
Any chance below 1/32768 will either map to 0 or 1/32768, depending on
the precise algorithm. This could end up quite skewed.
Because rand() is cyclic and deterministic, your cycle time is only
32768. This can cause problems when doing sequential random
numbers. For example, say a humanoid creature has a 0.1% chance of being
generated with a random wand that it knows how to use.
There will be ~32 numbers that rand() could have produced that would
do that. Say that it then selects the wand type from 1d100 on this list:
1-10: light
11-20: darkness
....etc...
97: death ray
98: earthquakes
99: disintegration
100: ultimate doom
There are only ~32 numbers that could have led to the wand being
created. Since each of those numbers has a definite successor, there
are therefore only 32 possible outcomes of the d100 roll that can
actually happen (and the birthday paradox suggests that some of these
will be the same, which makes it even worse).
So it might be impossible to get a monster generated holding a wand of
earthquakes, or it might be a 3% chance rather than a 1% chance that
the wand is of ultimate doom, or other oddities.
So you'll get very odd situations occuring, possibly in a way that's
very bad for game balance, that never occurred when you compiled
against a better RNG.
There was a thread on rgrm not long back mentioning similar problems
with RAND_MAX on minGW being 32767.
Chris
G
Guest
Guest
>32768.
The C standard does not, as far as I know, stipulate any relationship
between rand()'s period and the size of RAND_MAX.
For example, in glibc, rand() points to an implementation of
Berkeley random(), which has a limit of (2^31 - 1) and a period of
16*((2^31)-1).
G
Guest
Guest
> Effects of this:
> 32768.
Wrong. The cycle period is determined by the size of the internal state of
the RNG, not by the number of different possible results.
Of course, it doesn't mean it has to be different either. In that particular
case, maybe it is the same.
G
Guest
Guest
In article <87vf11cmnn.fsf@dinopsis.dur.ac.uk>, c.i.morris@durham.ac.uk
says...
Nothing wrong with that, IMO.
> Effects of this:
There are easy ways to avoid this.
> 32768.
This isn't the case - MSVC uses a 32-bit internal seed. The reason it
returns a value from 0 to 32767 is that it returns only the 15 middle
bits of this seed. This is *good*. If it returned the complete seed
you would get artefacts such as numbers being alternately odd and even
etc.
In fact rand() is not bad for general use, though if you seed with the
system time you should call it a couple of times before using it.
However, for a roguelike it would indeed be preferable to use something
more sophisticated. For most games, you could happily stick with
MSVC's version of rand().
- Gerry Quinn
G
Guest
Guest
> etc.
> something more sophisticated. For most games, you could happily stick
> with MSVC's version of rand().
These statements completely ignore all of the problems that result from
using bad random number generators.
Jim Strathmeyer
G
Guest
Guest
In article <o5ydnR_ZPvv-xLHeRVn-oQ@adelphia.com>,
strathWHATEVERIGETENOUGHSPAMANYWAYS@ipass.net says...
> > etc.
Because for many games, they can be ignored.
- Gerry Quinn
G
Guest
Guest
>> from using bad random number generators.
Uh... which games?
Jim Strathmeyer
G
Guest
Guest
> Uh... which games?
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
int main()
int guess;
srand(time());
printf("Guess a number from 1-10!\n");
scanf("%d", guess);
if (guess == (rand() % 10))
printf("You guessed right!\n");
return 1;
printf("Too bad, better luck next time.\n");
return 0;
(Before the pedants attack: no, I have not tried to compile this)
Jeff Lait
G
Guest
Guest
In article <IPCdnaEMWfKlMrDeRVn-jQ@adelphia.com>,
> Uh... which games?
Most games don't require sophisticated RNGs.
If you just have standard play areas, or not-too-complex random ones,
and certain enemies and/or objects appear at somewhat random times,
none being grossly uncommon, rand() will probably do fine.
And the above covers a LOT of computer games. Lines, Tetris, Space
Invaders derivatives, etc.
- Gerry Quinn
G
Guest
Guest
At Mon, 19 Sep 2005 13:10:59 +0100,
>> Uh... which games?
What this newsgroup is about, again?
($s) 3 Ching!
