P Pbnj12 Honorable Nov 8, 2013 7 0 10,510 Nov 8, 2013 #1 hello, on this monitor im going to be gaming. i have a nvidia gtx 770 graphics card. I just want to find an affordable 1920x1080p 24in monitor thats great for gaming. I would like to keep the price at the 200 range thanks for your time
Solution manofchalk Nov 8, 2013 Pretty similar to the one mentioned above, but uses an IPS over a TN panel. Will net you more accurate colours and better viewing angles, at the cost of 3ms of response time. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236331
COLGeek Cybernaut Moderator Apr 6, 2009 59,738 5,399 184,340 Nov 8, 2013 #2 I would suggest this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153 Upvote 0 Downvote
manofchalk Glorious May 11, 2012 12,913 6 48,960 Nov 8, 2013 Solution #3 Pretty similar to the one mentioned above, but uses an IPS over a TN panel. Will net you more accurate colours and better viewing angles, at the cost of 3ms of response time. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236331 Upvote 0 Downvote Solution
