I need help finding a GOOD (OC capable) mobo, $100 or under, that has decent space between the CPU and PCI-E slot, -- or one that will comfortably fit a Cooler Master GeminII CPU heatsink with a 8800 GTS in the PCI-E slot.
The reason is I just purchased a Cooler Master GeminII and as awesome as it is, it takes up a lot of space!
The other parts which will be going into this mobo are:
-Athlon X2 5600
-Nvidia 8800 GTS 640MB
-Western Digital Caviar 160GB 7200 RPM
-A-DATA 2GB DDR2 800 Dual Channel
-Broadway Com OKIA ATX 550W PS
I've been looking at some nForce 570 SLI boards, but the first PCI-E is too close to the CPU and the second PCI-E only runs at 8x!
Help!
-Athlon X2 5600
Help!
