[SOLVED] Need Help Fixing Problem
Jul 4, 2020
My PC Keeps I’m turning on, waiting a few seconds, turning off, then turning on again, waiting a few seconds and turning off. It does this about 2-4 times. Then, it stays turned on however I don’t get any HDMI signal from my graphics card (GTX 1060). I just dusted it out, and it started doing that. Help please!
You likely knocked loose a connector or something.
Reseat ram. Try making sure all connectors are not loose.
I wouldn't be surprised if your gamemax PSU has failed tho, they are rather poor quality.
