Need Help FPS Problem!
MysticLeeeroy
7
Hello there I need help! Recently I just picked up a gtx 1060 like two weeks ago and the first week been great till the second week I started encountering issues. The first issue I encounter was GPU crash. The way it started was the first week I was able to play all my games fine on ultra settings and was able to stream fine on ultra settings, got the card around April 28, and the issue started on May, 4 and started with Black screen. I decided to play PUBG and after I got off the game, my monitor went black and had to reboot to get it back to normal. My GPU crashed about 6 times playing or even attempting to open PUBG. We found out it was just a bad rail weaking on the southbridge and ended up using another rail. This fixed the problem and started working again.
After that issue was solved, I started encountering another problem afterwards. When I attempt to not stream on OBS, my GPU is fantastic, now when attempting to stream on OBS it goes to hell. I start lagging completely and stuttering when OBS is open or attempt to start streaming. Let me tell u last week, it wasnt even doing this. I need to know what to do now and how to get the pc back up and running. Here is the info of my pc and logs for OBS:
CPUZ: https://valid.x86.fr/xnvny8
OBS: Logs https://gist.github.com/anonymous/1569255685249faa49b2e20bddd55e5c
PC Hardware:
Tower: X-Titan Black Mid Tower
MotherBoard: Z87-K Asus
Graphic Card: MSI GTX 1060 X 6G
Ram: 16GB(2x8GB) HyperX Fury DDR3
CPU: Intel Core i7-4770k
liquid Cooler: Corsair H55 Series
HDD: 1TB Toshiba and 1TB WD
PSU: Apevia ATX-900W
Currently Dual Monitoring using iGPU: Main Monitor on GPU 2nd monitor on Motherboard.
When GPU and CPU when idle:
https://gyazo.com/93f997c01f6254d079b78b824d7d5118
https://gyazo.com/38a606e22431760db3fcd12eb4b2117f
When Gaming on CS:GO:
https://gyazo.com/f529e7899bf90bd40bcb6b966aac320d
https://gyazo.com/e929a4b41ace2e55e13bb4487955cfc8
When OBS is open while CS:GO open:
https://gyazo.com/56506bfed0f242bc826f4b7c62299880
https://gyazo.com/c01e2420cdd893e9e94543f80ff67f5f
This has been a pain lately struggling attempting to stream knowing your going to lagg really hard, attempting to change ingame settings doesn't work fully as well, just gets worse.
I would say a motherboard defect some just come you know defected. And what mode of video are you using? Because if the cable is broken try using another one but put the graphics card in the top slot. Also if you are having issues with the graphics card have you downloaded the latest drivers and enabled for it to be your main video passthrough? If all else fails you have two options send back the motherboard or gpu easy they will replace it.
