Hello!
I hope someone can help me otherwise I don't see any other way then RMA my gpu..
My GPU started to make a lot of noise since ±3 weeks. Idle temps are fine (around 30-35 degrees), but when I start a game (even older ones at low settings, games I played at ultra settings in the past without a problem (ie Civilization 6) the temps rise quickly to 78-80 degrees and then the fans keep blowing at 100% and it keeps going over 100% even (100% is 3100rpm, it oftens goes to 3900rpm and back). It also does this with other games I played before. What I've tried so far:
I attached a picture of GPU usage, temps and fans RPM, this is of game Civilization VI at low settings, framelimiter to 60 fps at 1440p. (GPU gebruik = GPU usage)
Does anyone has another idea or tip? I still have warranty till 04.2022 so I could RMA it, but I've read some stories that people often get their cards back with same problems.
Thanks in advance!
Sorry for my English.
- I have cleaned my PC and removed all dust (also tried without side panels) = GPU gets to 78-79 degrees
- Fans seem to spin all 3 equally to me.
- Tried to start with a fixed 90 and 100% fan speed but then temp still rises quickly to 78-80 degrees and fans start spinning very loud.
- Removed and reinstalled latest NVIDIA drivers
- Deleted all third party software that could influence fan control = no difference
Thanks in advance!
