bigshootr8 :
I guess its just personal preference both are good cards. The power edition card has a factory overclock where as depending on the DCUII card you are looking at it may not. Either way both cards will feel the same performance wise and if you get a game you want from one and not the other then perhaps the better value is with the ASUS card for you.
I also have another quick question
My friend has a H-I41-uATX (Eton) motherboard.. he is wondering if a GTX 550 TI will fit inside his pc..?
Quick Question Thanks
