Question Need Help High Temperature on CPU Bought Custom
Brandon1228
9
Hello,
Thanks for reading need some help. So instead of building my PC like last time ordered on CyberpowerPC. Came in and plugged in everything but after 10 minutes of the computer being on in would turn off. So, decided to look at the temperature, and its going to like 100C. I bought 10% overclocking and thermal paste option there but I think they messed it up or didn't put thermal paste or got messed up travel. IDK. So I need help resetting my CPU to factory settings or need to reapply thermal paste (Wont come until 28th). Specs are going to be found below if you have any ideas to help would be much appreciated. CPU-Z got it going at 4800. The temperature just going into is like 60-90. Get a good 5 minutes on the desktop looking at the temperature before my computer turns off.
CARE2: CPU Thermal Compound - Our Cooler Master MASTERGEL High Performance Thermal Compound can improve cooling performance as well as prolong the life of your CPU. [+10]
CASE: LIAN LI PC-O11 Dynamic EVO ATX Mid-Tower Dual chamber Gaming Case w/ USB 3.1 Type-C, Tempered glass on the front & side [No Fan] (Black Color)
CPU: Intel® Core™ Processor i9-12900K 8P/16 + 8E 3.20GHz [Turbo 5.2GHz] 30MB Cache LGA1700
CS_FAN: ThermalTake 120mm Pure Plus 12 LED RGB Radiator Fan TT Premium Edition PWM 500~1500rpm (3 Fan Pack) w/ Software Controller [+59]
FAN: Cooler Master MasterLiquid ML360 Mirror 360mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate [+20]
HDD: 2TB SAMSUNG 980 PRO (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7000/5100 MB/s, Rnd R/W up to 1000/1000k [+204] (Dual Drive (2TB x 2 (4TB Capacity)) [+293])
HDD2: 2TB (2TBx1) Seagate SATA-III 6.0Gb/s 256MB Cache HDD [-11] (Single Drive)
MEMORY: 32GB (8GBx4) DDR4/3600MHz Dual Channel Memory [-30] (Team T-Force Delta RGB [+10])
MOTHERBOARD: ASROCK Z690 EXTREME ATX DDR4, ARGB 2.5GbE LAN, 3 PCIE X16, 1 PCIE X1 4 SATA3 3X M.2 SATA/PCIE [+78]
OS: Windows 11 Home
OVERCLOCK: Pro OC (Performance Overclock 10% or more)
POWERERSUPPLY: 1,000 Watts - Corsair RMx RM1000X 80 PLUS Gold certified Fully Modular Ultra Quiet Power Supply [+57]
VIDEO: GeForce RTX™ 3080 Ti 12GB GDDR6X (Ampere) [VR Ready] [+184] (Single Card)
Thank you. I think I will do this and just reapply thermal paste at the same time in two days. I just took the motherboard CMOS battery out to reset the motherboard to see if that would fix but its and still running hot so I think its the fan which BIOS says is on going at 2000 RPM but might not be placed properly but ill do it two days to see if fixes the problem.
