Question Need Help in budget mobo for I5 12400f.
Zuber Khan12
96
6
18,545
Hello Community,
I am building a budget PC for gaming, already purchased RTX 3060ti and I5 12400f, Searching for a budget mobo, not looking for anything fancy, just want this mobo to be durable and to give good performance.
So far it seems H610 and B760 feels in budget.
I have finalize few :
https://amzn.in/d/04fLQwFU MSI PRO H610M-E DDR4 - ₹6,175 - $73.90
https://amzn.in/d/09J5426D MSI PRO H610M-E DDR5 - ₹6,999 - $83.76
https://amzn.in/d/05u3sCdJ MSI PRO B760M-E DDR4 - ₹9,380 - $112.25
https://amzn.in/d/0caAHVKr MSI PRO B760M-E DDR5 - ₹10,400 - $124.46
Personally, i feel MSI PRO H610M-E DDR5 is a good choice since i am getting ddr5 and also cheap.
i am not going to upgrade my pc atleast for 5 6 years, so not looking for futureproof.
Need suggestions!
Aeacus
Ambassador
H610 chipset is as barebones as it gets. So, if you want cheap, go for that.
B760 has more features and is more reliable, that the cheapest of the cheap. So, you have a tradeoff, cheap price - low reliability; higher price - good reliability. Up to you.
For maybe a cheaper price than B760, look towards B660 chipset MoBos. Those do support DDR5 as well but can be cheaper than B760 chipset.
Compatible B660 MoBos with DDR5 support: https://pcpartpicker.com/products/motherboard/#mt=ddr5&c=154&sort=name&page=1
Reactions: Zuber Khan12
Zuber Khan12
96
6
18,545
Thank you for your response, sir,
Yes, reliability is one of the main thing i would like to have,
Let me check the link you share :)
Zuber Khan12
96
6
18,545
I have done some searching and here in india B660 is not easily available(online), and also same or costly then B760 chipset.
