Question need help in connecting 3 switches to a router
Mar 16, 2020
i have 3 switches (S1,S2 and S3). A router and a NVR.
i am trying to connect NVR to LAN. at the moment NVR seting is done without LAN connection.
so, laid a cable from my router to S1. and then i used another cable to connect S1 and S2.
and another cable to link S1 and S3. so, basically 2 cables going out from S1. 1 to S2 and 1 to S3.
Router -------> S1
S1 ------------> S2
S1 ------------> S3
S3-------------> NVR
Router IP is 192.168.18.1
NVR IP is 192.168.18.2
after connecting like this i am not able to router or NVR or internet. i thing a loop is being created because of the way i am connecting these switches.
can anyone help?
It should work fine. If the switches you used are "managed" or smart switches you may have a misonfiguration. Unmansged switches you can just hook up.
You do not have a loop. A loop would be if you were to say connect s3 to s2.
Make sure all the ports are have the proper lights maybe you have a bad cable.
