Hello forum,
I have a Dell M6300 with an NVidia Quadro FX1600M graphics card.
Long story as short as I can make it: some time ago, I upgraded from XP to Win7/64, and along the way I updated the NVidia drivers. When I installed Mastercam X8, I had to roll back the drivers to avoid some display issues, at which point everything worked great. I then swapped the HDD for an SDD, and in the process I did a clean install of Win7/64. This reintroduced the graphics display issues in MCX8, but I'm unable to roll back to anything but the Windows default driver. I loaded the old HDD and found that I was successfully using an XP/64 driver from 2012, so I put the SSD back in and downloaded that driver from NVidia. Unfortunately, despite the fact that it works in the upgraded Win7 environment, it won't let me install in the clean environment because it says the driver is not compatible.
Is there a way to get around this installation roadblock, perhaps by manually copying the drivers into the correct locations? I've never done so, but might booting Win7 in XP mode allow me to install the older drivers?
Thanks for your help,
Nick
Nick
