Need help making my Packard Bell PCI 2.2 compliant.
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.packardbell (More info?)
Award Modular BIOS v.4.51 PG
Packard Bell FR510 BIOS v.00.01.18
11/25/1998-ALADDIN5-2A5KKG5DC-00
MOBO S/N: E093026283
Model: 930/950
Chipset Ali M1541 (GVC)
I have a PB running 160 MB RAM and Win 2k Pro SP4. I tried to install
the Wireless PCI Adapter after the SW itself was installed (per the
directions/manual), and upon reboot, the Hardware Found Wizard did NOT
detect the new Card.
I tried to manually install the card as well, but it is not listed even
though I select the correct /drivers directory in which it resides.
Based on the 930/950 manual, the PCI is only 2.1 Compliant, and Netgear
requires 2.2 Compliance, and I assume this is why the Card isn't being
recognized.
Would an easy solution be to upgrade the motherboard to the next ATX
iteration, I don't think updating the BIOS chip will have an affect,
but it's hard to tell based on what I've read.
Thanks for reading, I promised my 7 year old daughter that I'd have
internet in her room on this PC, and she's starting to doubt dear old
dad.
Thank you so much for the quick reply.
I was afraid that any sort of BIOS upgrade wouldn't help, even though
PB support said the BIOS Chip itself was PLCC, ie, replaceable with an
entirely different and newer one.
At any rate, you mention 3 options, I'm also wondering if I couldn't
replace the ATX Form Fit (12 x 7.5) MotherBoard with the next iteration
board that IS PCI 2.2 compliant.
Do you see this as a possibility as well?
Once again, thanks ever so much.
The limitation you are seeing is in the VIA Aladdin chipset. A BIOS upgrade
will not get the system to PCI 2.2 compliance. Your best bet with WiFi on an
older computer is to install a PCI-PCMCIA adapter card, then a notebook-style
PCMCIA 802.11b card.
Your second best bet is another brand of contemporary Wifi PCI card, but check
the specs first. A Linksys card might work just fine.
The third, and possibly worst, choice is a USB WiFi adapter. But your system's
motherboard does not meet the USB 2.0 spec, so the WiFi might not run very fast.
As with PCI, it would be best to check specs on any USB WiFi adapter you buy to
make sure it can be used with USB 1.1... Ben Myers
>Model: 930/950
>recognized.
>dad.
Yes, a newer ATX or even micro-ATX board would do just fine. If you go for a
Pentium 4 motherboard or boards with certain AMD CPUs, you need to replace the
power supply with a Pentium 4-capable one. If the power supply is rated at less
than 200 watts, replace it even with a Pentium 3 board... Ben Myers
D LINK USB wireless adapter is compatible
check out their site firest
www.dlink.com
I use D link on an older system
Their pci cards are 2.2 which is a no go
You will never see the difference for a 802.11b vs 802.11g
since both a greater than the badwidth of your provider
Now if you use ad hoc peer to peer than that is another thing altogether for
speed concerns
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:41b7b0fe.15504493@nntp.charter.net...
> for a
> the
> at less
I already Purchased a Netgear Wireless Router that came with a Notebook
Card (in which I don't have a need for right now) for $20. I also
already purchased 2 Netgear Wireless PCI Adapters, one was $30 after
rebate, the other was free after I used a $30 store gift certificate,
and after rebate.
For $50, I have a wireless router, a Notebook card, and 2 PCI adapters,
so I'm all set on that front.
I just need this older ATX Form Factor to recognize the card, that's
it.
I've heard very good things in regards to Netgear and wireless coverage
in terms of distance from the router, which is fairly essential for me,
whereas I haven't heard similar good things in regards to LinkSys and
Belkin from people I know that have tried those, ie, wireless coverage
is not very far from the router.
Thanks,
bd420
"metronid" <metronid@comcast.net> wrote in message
news:FrKdnZJmaPJqKSrcRVn-vQ@comcast.com...
> www.dlink.com
> for speed concerns
There is also a brand that runs well here in my home town. Called "Hawking"
http://www.hawkingtech.com/ which is sold in CompUSA in New York.
Cheaper in prices and easy to install. I was amazed when I just did a job
where the guy bought this brand. But check the fact sheets.
All sorts of products from this company.
Elector
I've used lots of Linksys gear and had very few problems with it. I've also
used Proxim Orinoco Gold cards, an older business/corporate standby.
Suffice it to say that different brands of WiFi interoperate quite well with one
another.
You might try that Netgear notebook card in another brand of PCI-PCMCIA adapter
card. AFAIK, Netgear does not make PCI-PCMCIA adapters, but there are others
kicking around out there.
You might also try a Linksys 802.11b or g PCI card, but check the specs first.
Price is around $50.
You may have gotten great prices on the Netgear stuff, but if it doesn't all
work, the price does not look as great any more. For it's low street prices,
Netgear seems to have sacrificed motherboards with older PCI specs.
.... Ben Myers
>and after rebate.
>it.
>Thanks,
>bd420
Sorry to say the fact is your unit will never be PCI 2.2
That is the requirement of the card
It is not a bios thing
It is the PCI chipset that is part of your system
If you bought the item from compusa or such
it is returnable minus the 15% restocking
Usb is your only hope with certain cost constriants considered
Then there is Ebay to sell what you have and do a partial recovery for the
card
news:41b85daf.4822250@nntp.charter.net...
> also
> with one
> another.
> adapter
> others
> first.
> all
> prices,
> ... Ben Myers
>>and after rebate.
>>it.
>>Thanks,
>>bd420
I am always impressed with your succinct and helpful answers.
news:OdKdnagFSeWdICXcRVn-hg@comcast.com...
card
Requirement. I do have an old Celeron 633 CPU laying around that I
could slap onto an ATX MOBO?
Thanks,
bd
for the
> card
I've
> > also
standby.
well
> > with one
> > another.
PCI-PCMCIA
> > adapter
are
> > others
specs
> > first.
doesn't
> > all
street
> > prices,
> > ... Ben Myers
Notebook
after
certificate,
> >>and after rebate.
adapters,
that's
> >>it.
coverage
me,
and
coverage
> >>Thanks,
> >>bd420
I forgot. A micro ATX motherboard supporting sub-2.0v Socket 370 CPUs would
work, too... Ben Myers
>Thanks,
>bd
>for the
>> card
>I've
>> > also
>standby.
>well
>> > with one
>> > another.
>PCI-PCMCIA
>> > adapter
>are
>> > others
>specs
>> > first.
>doesn't
>> > all
>street
>> > prices,
>> > ... Ben Myers
>Notebook
>after
>certificate,
>> >>and after rebate.
>adapters,
>that's
>> >>it.
>coverage
>me,
>and
>coverage
>> >>Thanks,
>> >>bd420
Yes, provided that the ATX motherboard is a Socket 370 capable of supporting the
sub-2.0v power requirement of a Celery 633. Earlier Socket 370 CPUs operated at
2.0v, and many earlier Socket 370 motherboards were designed very shortsightedly
for just the 2v CPUs... Ben Myers
>Thanks,
>bd
>for the
>> card
>I've
>> > also
>standby.
>well
>> > with one
>> > another.
>PCI-PCMCIA
>> > adapter
>are
>> > others
>specs
>> > first.
>doesn't
>> > all
>street
>> > prices,
>> > ... Ben Myers
>Notebook
>after
>certificate,
>> >>and after rebate.
>adapters,
>that's
>> >>it.
>coverage
>me,
>and
>coverage
>> >>Thanks,
>> >>bd420
is 90 Watts, which I'm reading is pretty bad, ie, 200 and 300 Watts is
the newer norm.
How do I know that a newer ATX MOBO will play well with a 90 Watt Power
Supply? Is there a Compliance chart for which MOBO will work with
which Wattage Power Supplies?
Another way of asking this question is, what 'could' happen if I place
a relatively newer 7.5 x 12 inch Form Factor ATX Board in this machine
and it's too much for the 90 Watt Power Supply?
Thanks, and once again, EVERYTHING about this machine would have been
just perfect, had the PCI Slot been 2.2 compliant; I seek NO other
upgrade whatsoever, I'm completely content with everything about this
free machine, I just need to find a 7.5 x 12 inch MOBO that has a PCI
2.2 Compliant, and will be ok with the current 90 Watt PSU (Power
Supply Unit).
CPUs would
> >Thanks,
> >bd
> >for the
> >> card
it.
> >I've
> >> > also
> >standby.
quite
> >well
> >> > with one
> >> > another.
> >PCI-PCMCIA
> >> > adapter
there
> >are
> >> > others
the
> >specs
> >> > first.
> >doesn't
> >> > all
> >street
> >> > prices,
specs.
> >> > ... Ben Myers
> >Notebook
also
> >after
> >certificate,
> >> >>and after rebate.
> >adapters,
> >that's
> >> >>it.
> >coverage
for
> >me,
LinkSys
> >and
> >coverage
> >> >>Thanks,
> >> >>bd420
