Re: Shuttle AN35N-Ultra V1.1 (newly purchased)
As usual when doing a new build, I set up the mobo o/s the case for testing before going on to install inside case. Installed cpu (Barton 2500), HS+F, ram and agp vid card, no drives. Hooked up both 12v ATX power connectors, power switch and case speaker (for any diag probs/beep codes which may arise).
Well, when I hit the rocker switch at the rear of the psu, I get the green and red LEDs, but nothing when I hit the power button. Tried two different psu's (one known working) to rule that out. Then tried shorting with screwdriver the "power on" (on JP13 for those familiar with this model)pins on the mobo to rule out bad power button on case. Still nothing
Am I missing something, did I short properly to rule out power switch probs, or is this a "DOA" which I need to RMA?
Edit: K, looks like agp card. When removed cpu fan spins, no beep codes though. Card is apollo S3 Savage IX, I assume it's a 3.3v card instead of 1.5 v.
Thanks,
Mobile XP 2600+ (11X200)
Abit NF7-S v 2.0
Maxtor 60GB ATA 133 7200RPM
512MB Corsair Twinx 3200LL
BBA 9800 Pro
Enermax Noisetaker 420 watts
Win98SE<P ID="edit"><FONT SIZE=-1><EM>Edited by Coyote on 06/16/04 04:55 PM.</EM></FONT></P>
Thanks,
Abit NF7-S v 2.0
BBA 9800 Pro
