This is my build: https://pcpartpicker.com/list/sNWm7W
My first ever build so I must be overlooking something. I connected the front panel cables correctly, following the manual. I turn it on and the LED lights turn on, the MOBO lights turn on but nothing else happens. The wraith cooler/GPU/PSU fans aren't spinning and the monitor says no signal.
I followed all the manuals, step-by-step, and checked online tutorials.
Placed the CPU in the correct orientation, fell right into place.
Placed the wraith cooler directly on top of it with the screws aligned, tightened and connected the cable to CPU_FAN.
Connected the 24-pin to the motherboard (at ATX-PWR1), already coming out of the PSU.
Connected 8 pin to the motherboard (at CPU_PWR1), already coming out of the PSU
Connected the 6+2 pins from the PSU to the GPU.
Connected 2 SATA cables to the SDD, 1 from MOBO and 1 from PSU.
Installed both RAMS on the indicated slots for the first two (slot 2 and 4).
Connected 12V input (in the case) to the PSU.
If you want to see any pictures of the wirings just message me.
Any help would be appreciated.
