I've put together a PC with the following Specs:
PSU: Corsair CX 600 W
GPU: MSI 1080
CPU: AMD Ryzen 5 3600
MB: AsRock AB350 Pro4
RAM: 16gb 3000 GHz
Storage: Samsung 860 EVO SDD (Not connected)
I bought the motherboard used (supposed to be in working condition). It was cheap enough for me not to even bother with a test run, I'm wondering if it could be dead. I want to make sure I check everything else first though before buying another.
I know I will have to update the BIOS for the 3600 but I thought I could do that with it installed.
When I power on I get no output from the GPU, everything on the board powers on, runs for about 7-10 seconds, then cuts off and then repeats this until I manually cut it off.
Any ideas for troubleshooting? Thanks for any responses.
GPU: MSI 1080
RAM: 16gb 3000 GHz
