Lupiron
Maybe!!
Run Core Temp, or real Temp, and list what the VID is of the processor. That is the established factory voltage for your chip at stock speeds, when Vdrop and droop are applied it will be lower actual.
To check VDrop and droop, get the VID, return to stock, manually enter the VID voltage as the Bios voltage, disable speed step, disable C1E, disable any eist junk, disable spread spectrum...
Boot to windows, and run CPUz, and look at the current Core Voltage after windows has booted, and idled down. That will show your Vdrop, the difference from Bios VCore to idle windows.
Next, run Prime 95 small ffts on all cores and after 1 minute, note the lowest value you see CPUz show your core voltage as!
List em all here, and we can take a peek and see!
--Lupi
--Lupi
