I have the following parts
Q6600
Asus Maximus formula
8800gts 512mb
2gb corsair ram
700 watt psu
2x wd 500gb hard drives
ok i have it set to 3GHz, however for voltages in the bios it has 2 settings for the cpu:
1. CPU Voltage
2. CPU PLL Voltage
i have cpu voltage set to 1.27 however in cpuz it shows it at 1.240volts and it shows the same reading in pc probe as well
i have cpu pll voltage set to auto, im not exactly sure what to set that to
also with core temp 0.96 it shows my cpu with the following temps:
Core #0 30c
Core #1 30c
Core #2 25c
Core #3 25c
this is totally idle, is that ok gor G0 stepping or?
also for prime 95 what test should i run? blend or?
*im pretty sure there is something wrong because i cant start speedfan and prime 95 wont even open lol... however i was able to run 3dmark 06 without any problems and hitting 14120. I think it has to do with the voltage not being high enough so i need to fix that
please help thanks
Q6600
8800gts 512mb
2gb corsair ram
700 watt psu
1. CPU Voltage
2. CPU PLL Voltage
Core #0 30c
Core #1 30c
Core #2 25c
Core #3 25c
please help thanks
