Need help on extreme budget PC
gerane
37
I just built my own PC a few months back, and now that I have, my wife constantly nags me about how hers is terrible, and mine is nice. Hers has some major age on it, and has a few things are about to fail. Nothing i'd say is really salvagable from it due to its age.
Approximate Purchase Date: Maybe a few months down the line.
Budget Range: As low as I can get it. below 200 would be nice.
System Usage from Most to Least Important: School, web surfing, youtube. Her school does require some heavy excel and some statistics programs, and some other assorted programs, but don't think they are that system instensive.
Parts Not Required: mouse, keyboard, windows, speakers, GPU and possibly monitor. If I went with a new monitor I know my budget would have to go up. i'll have to double check her PC regarding her old drives. I'm thinking they are likely not SATA, same as her HD.
Preferred Website(s) for Parts: tigerdirect or amazon. Can't use newegg since it has an office in my state and charges sales tax.
Country of Origin: USA
Parts Preferences: None
Overclocking: None
SLI or Crossfire: None
Additional Comments: This PC doesn't need to be that powerful, it just needs to do the easy stuff well. No games will be playing on this pc, and if there one day was, Ill just throw my old low end GPU in it from my old PC. I am not very familiar with the compenents at this low of a budget, so an advice would be appreciated.
athlon II 440 : ($65)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103941
Rosewill RCX-Z80-AL cooler: ($10):
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200042
mobo N68-UCC: ($40):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157202
Sony Optiarcv DVD-RW drive: ($20)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
Rosewill R102-P-BK case: ($30)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147111
4GB DDR3 1333Mhz crucial ram: ($20)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148346
Seagate Barracuda ST500DM002 500GB 7200 RPM HDD: ($40)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
antec BP350 PSU: ($30)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371003
comes to $254.92 after rebates.
possible upgrades:
ASUS EAH5450 ATI 5450 graphics card ( $35 not needed really):
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121444
possible downgrades:
Crucial 2gb 1333Mhz DDR3 ram:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148221
athlon 250 ($60 you wouldn't need the CPU cooler with this processor):
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103903
this case: ($22)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233061
the tri-core athlon will also have a chance of unlocking into a quadcore athlon! (or even a quad core phenom!) even if it does not it will be able to handle everything you listed with ease.
with downgrades it would come to $222.93 for a system still more than capable of the tasks listed.
[EDIT]:
just read about the 'no newegg' if you just get the same parts from tigerdirect it woulod probably cost a similar price.
tiger direct athlon 250:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6718200&CatId=4667
Seagate ST3160316AS Barracuda 7200.12 Hard Drive - 160GB HDD:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=143901&CatId=2457
Asus M2N68-AM PLUS mobo:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5508969&CatId=2874
HEC 6T10LITE 6T10 case:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=735786&CatId=3427
2gb ddr3 1333Mhz ram:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6075366&CatId=4534
Lite-On IHAS124-04 DVD-RW drive:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4829307&CatId=1624
Antec BP350 PSU:
http://www.amazon.com/Antec-BP350-Basiq-Power-Supply/dp/B000H9J3ZC/ref=sr_1_1?ie=UTF8&qid=1315319347&sr=8-1
total: $235.94 (for a dual core system and this doesn't even include shipping!)
just saw this case on amazon too: (for only $19 but $8 PandP)):
http://www.amazon.com/Tower-Aluminum-Desktop-Computer-Case/dp/B005GFKZFE/ref=sr_1_94?s=pc&ie=UTF8&qid=1315319718&sr=1-94
