Need help on upgrading Graphics card
Manlysloth
11
Hello, i want to upgrade my 6770 to a 7870 and would like to know what is necessary to upgrade, i'm on a budget of around $400
I currently run the following
-i5-2500
-8gb of ddr3 1600(unfortunately limited to 1333 as i'm a derp)
-Asus 6770
-GA-H61M-S2P-B3
-And an Cooler Master Elite 342 which came with the thermal master 420w Psu
If i have left out any details, please inform me.
You have a good cpu and 8GB(doesn't matter much the difference 1333vs1600 in performance).
What you'll need is a new good psu and a card.
Psu :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
or http://us.ncix.com/products/?sku=59615&vpn=P1550SXXB9&manufacture=XFX&promoid=1285 (recommended)
Cards :
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
If you want you can have the 7950(with the psu it stays from 400$ maximum):
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
Psu :
Cards :
Yes it was the point of the z68/z77 to overclock the i5-2500k, then you don't need to change the mobo, just the psu and gpu.
And one more thing that makes me not recommend a new mobo, is the arrival of the new lga 1150 and the new intel cpus(haswell) for 2013.
