Question Need help on with X470 motherboard and cpu compatibility.
Jul 14, 2019
I purchased a 3700x with a Asus Prime X470 Pro motherboard, and unfortunately it requires a bios update and it doesnt come with flashback bios so im in a pickle, im thinking of buying a cheap processor like the 200GE to just update it, however it seems that would also require a bios update. Which CPU would work out the box with the X470 that is cheaper than £80 and if it isnt please still state thanks, and any other way i can get around the fact theres no USB Bios update? Thanks.
Reactions: A Thicc Turtle
Jul 14, 2019
Dang that stinks man.
I've heard that you can get BIOS updates at places like Micro Center, who will plop your motherboard into a temporary system to update the BIOS for you.
Unfortunately there isnt a computer specialist near me, just repairs and stuff. I called for prices and they charging £90 so i thought a processor would 100% be a better option. Not many other tech repairs so they charging abnormal prices.
Jul 14, 2019
