Need help pickign a motherboard
pwrhungry01
21
I will be getting <A HREF="http://www.falcon-nw.com/fragbox.asp" target="_new">this case</A> with the AMD Athlon64 3000+ Socket 939, 1 GB Ram, 2 36GB 10,000rpm WDHD's, and either the 6800 GT or Ultra. Cant for the life of me figure what motherboard to get that will fit in this case. Anyone have any experiance with it or know what I need for sure? If you have any suggestions as to why I shouldnt get something I am considering buy please let me knwo and why.
BTW Reason for not haveing them do it is about $800 saved
I would go with one of the 74GB Raptors instead of two of 36GB. If you're thinking RAID0 with the two 36GB, then start reading in the Anandtech HDD section on RAID0.
Why are you going with a SFF case with a high-end gaming system? How are you even going to get the case without buying the system? Anywhoo, Falcon probably has a mobo mfr make a micro ATX board to their specs. Not familiar with good micro ATX boards, So I won't comment there...
Good luck on finding the right board for your system!
__________________________________________________
<font color=red>You're a boil on the arse of progress - don't make me squeeze you!</font color=red>
<-----Just noticed the new title! 😎 :smile:
good LANing experince dragging a 10L water bucket around
Who are you kidding - that's your exercise routine!
How the hell did you get there so fast? Are you related to Arnold?
😱 If I would have shot you when I had the chance, I would be out by now 😱
Intel P4 550(3.4)@<font color=green>5Ghz</font color=green>
OIE! Not looking forward to that!
Lots of trying to drill answers into knuckleheadedness!
