Need help picking a case
aaroncarlson
33
Hi all i need help deciding on a case. I plan on doing future water cooling and i want really good airflow for my case. Im trying to decide between 3 cases.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147157
Here is my specs:
Case: Dont know yet
MOBO: Asus Maximus 5 Extreme
CPU: I5 3570k
CPU Cooling: CORSAIR Hydro Series H110 Water Cooler
RAM:CORSAIR Dominator Platinum 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133
GPU: Sli ASUS GTX680-DC2-4GD5 GeForce GTX 680 4GB
GPU Cooling: 2 ARCTIC Accelero Hybrid VGA Cooler
PSU:Rosewill LIGHTNING-1300 1300W
SSD: SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD)
The cooler Master HAF X case is possibly one of the most popular high end computer gaming cases on the market today, and that’s because it’s damn good. Starting with the appearance of this case, it’s absolutely stunning. The entire “tank like” chassis is finished in black and wrapped in some very high quality steel and plastic. As its name, high air flow, implies, the major selling point of this case is in its top notch cooling performance. Up front through the mesh grill you get a 230mm red LED lit fan sucking plenty of air into the case while up top you also get a large 200mm fan complemented with another 140mm fan to round out the exhaust system. On one side of the case you also get a large window covering 3/4 of the sidepanel allowing you to show off your components, while the other 1/4 of the window houses an extra large 200mm intake fan for unprecedented graphics card cooling performance.
Of course, the case also features some other pretty sweet features such as USB 3.0 front headers, full support for every motherboard size between mATX to XL-ATX, excellent cable management, tool free installation, SLI/Crossfire support, and even casters so you can roll this badboy around.
