N noor3y619 Reputable Sep 8, 2017 12 0 4,510 Jan 3, 2019 #1 Intel Core i7-7820X X-Series Processor 8 Cores up to 4.3 GHz Turbo Unlocked LGA2066 X299 Series 140W X299 SLI PLUS Motherboard GTX 1070 Any psu recommendations for this setup?
Solution jankerson Jan 5, 2019 noor3y619 : jankerson : noor3y619 : Will a Corsair 850W be okay? What Corsair 850W? CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Semi Modular Power Supply or CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Full Modular Power Supply Those can get loud and you don't need 850W. I would go with one of these and 650W or 750W. Seasonic Focus Plus Corsair RMX EVGA G2.
RARRAF Judicious Jul 22, 2007 3,981 109 35,440 Jan 3, 2019 #2 700watt Seasonic focus/prime or Evga g2/g3 Upvote 0 Downvote
J_E_D_70 Splendid Mar 21, 2012 7,294 59 30,290 Jan 3, 2019 #3 Are you using this for more than gaming? If not, X299 isnt the right platform. Upvote 0 Downvote
polbit Dec 30, 2018 19 0 10 Jan 3, 2019 #4 I'm a fan of EVGA G2/G3 as well, and for your setup 650W would be plenty. Upvote 0 Downvote
N noor3y619 Reputable Sep 8, 2017 12 0 4,510 Jan 4, 2019 #5 Will a Corsair 850W be okay? Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jan 4, 2019 #6 noor3y619 : Will a Corsair 850W be okay? What Corsair 850W? Upvote 0 Downvote
N noor3y619 Reputable Sep 8, 2017 12 0 4,510 Jan 5, 2019 #7 jankerson : noor3y619 : Will a Corsair 850W be okay? What Corsair 850W? CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Semi Modular Power Supply or CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Full Modular Power Supply Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 Jan 5, 2019 Solution #8 noor3y619 : jankerson : noor3y619 : Will a Corsair 850W be okay? What Corsair 850W? CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Semi Modular Power Supply or CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Full Modular Power Supply Those can get loud and you don't need 850W. I would go with one of these and 650W or 750W. Seasonic Focus Plus Corsair RMX EVGA G2. Upvote 0 Downvote Solution
N noor3y619 Reputable Sep 8, 2017 12 0 4,510 Jan 5, 2019 #9 jankerson : noor3y619 : jankerson : noor3y619 : Will a Corsair 850W be okay? What Corsair 850W? CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Semi Modular Power Supply or CORSAIR TXM Series, TX850M, 850 Watt, 80+ Gold Certified, Full Modular Power Supply Those can get loud and you don't need 850W. I would go with one of these and 650W or 750W. Seasonic Focus Plus Corsair RMX EVGA G2. Thank you Upvote 0 Downvote
