Need help please review my build and change if necessary
qwertyadsl
31
CPU Intel Core i5-3570K 3.4GHz Quad-Core $219.99
CPU Cooler Zalman CNPS9500 AT Ball Bearing $33.99
Motherboard ASRock Z77 Extreme4 ATX LGA1155 $134.99
Memory G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 $39.88
Storage Hitachi Deskstar 1TB 3.5" 7200RPM $59.99
Case Cooler Master HAF 922 ATX Mid Tower $79.99
Power Supply Corsair 750W ATX12V / EPS12V $109.99
Optical Drive Lite-On iHAS124-04 DVD/CD Writer $15.99
so basically this is my build is there anything to change??
i have 2 7750 which i will crossfire and i plan on buying a new card if necessary. i will overclock both gpu and cpu and is this 750w overkill?
i also have a question on ram there was this other g skill ram i think it was same specs and it was blue but it was 60 dollars should i go 2400 or just stick with 1600 ones.( im not sure on ram so please help me out on this spot)
please feel free to fix anything
thank you guys
http://www.amazon.com/gp/product/B008RJZQSW/ref=s9_simh_gw_p147_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=16VDDAAXWNZC1HKK4F2A&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846 $75.99 & this item ships for FREE with Super Saver Shipping
CORSAIR CX Series CX750 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1081367 $314.98 save: $25.00 FREE SHIPPING
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.amazon.com/Cooler-Master-Hyper-120mm-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_3?s=pc&ie=UTF8&qid=1349875820&sr=1-3&keywords=CPU%2Bcooler $30.99 & this item ships for FREE with Super Saver Shipping
Cooler Master Hyper 212 EVO CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544 $38.99 FREE SHIPPING $5 off w/ promo code EMCJNNA225, ends 10/10
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
Nothing there I would hugely disagree with. I tend to recommend the Coolermaster Hyper 212Evo, as the best budget CPU cooler. I wouldn't go beyond 1600 MHz, for RAM, it's just not worth the hassle.
HD7750 GPU's are a bit weak, to normally think of having them, in crossfire, but I suppose if you've already got them ....
The ASRock Extreme4 is the cheapest, fully featured Z77. I have, however, been hearing of overheating issues, with it, under high CPU load. Probably not a huge problem, with Ivybridge CPU, provided you are not planning to overclock, too agressively, but as long as you are aware of that limitation, still decent value.
For hard drive, obviously something like WD Caviar Black would be better, but more expensive.
Considering the 7750 doesn't use much power to begin with - 750W is major overkill. You could use a 500W even with two of them. If you plan to add a more powerful card later on then you would need extra power.
ViewRenameEditDeleteTotal: $698.80
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing $27.98
Storage Seagate Barracuda 1TB 3.5" 7200RPM $69.99
so this thanks for the reviews guys i guess this is my last call anything else to change i plan to buy this within a month so thank you for the help guys
Get the Ares instead of the Ripjaw - otherwise that's an excellent build, I say go for it.
and amy i ask whats the dif between ripjaw and ares?
and guys any recommendation for sound cards?
so ares is just smaller huh no performance difference and do i need a lan card? didnt built a pc in years
