[SOLVED] Need help!! PSU to GPU
agrnc
5
Hey everyone,
I just managed to buy a 3060ti (MSI Trio) and in my haste to literally get any 3060ti I could, didn't see that its 2 x 8 pin. My current gpu is a 8 and a 6 pin. The 6 pin is really a 4+2 I think. Am I okay to put the 4+2 into a 6 pin to 8 pin adapter then use that as the other 8 pin alongside my ACTUAL 8 pin? My psu would be able to support it, just unsure of the wiring and adapter part.
Yeah your PSU comes with 2 2+6 PCie cable. Each cable has 2 6+2 connector. You're gonna need to find your cables or buy some corsair compatible cable for your PSU.
Cables And Connectors
Native Cables
DescriptionCable CountConnector Count (Total)Gauge
ATX connector 20+4 pin (590mm)1118AWG
4+4 pin EPS12V (640mm)1118AWG
Modular Cables
6+2 pin PCIe...
I THINK it's the
Corsair CX-M Series CX650M 650 Watt 80 PLUS Bronze Certified Power Supply
but I can't double check, all I can see is the Corsair on the side, everything else is blocked by the PSU "cage" from the case. It's modular and I don't no where my cables are at this point so wanted to use an adapter. If there's no 4 and 2 pin then maybe it IS a 6...but I could have sworn it wasnt.
Native Cables
Modular Cables
6+2 pin PCIe (600mm+150mm)2418AWG
SATA (350mm+120mm+120mm+120mm)1418AWG
SATA (490mm+120mm)1218AWG
Four-pin Molex (450mm+100mm+100mm) / FDD (+100mm)13 / 118AWG
Native Cables
Modular Cables
Yeah, I'm an idiot, I just checked on my lunch break. They're both 6+2's. I'll be fine, LOL.
