Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi all,
I just recently upgraded to a
P4P800SE / P4 2.8E 1MB / 1GB Kingston 3200, OS WinXP Pro
I went with the onboard marvel NIC and the onboard 6 channel sound as
opposed to my 3com NIC and SB Live 5.1. I use the Cambridge DT2200 5.1
speaker set.
First off for sound, I have played with just about every setting i can
find and i still cannot get the front and centre speakers to work? I only
get sound from the back two and the sub. This is using the o/b sound card.
I even tried uninstalling the drivers for the o/b, setting up the SBlive and
still nothing? Is there anything i need to be looking for? It was working
perfectly fine on my A7V/Athlon850 right before?
Secondly, using the o/b marvell 10/100, the network connection to my server
is extremely slow. It seems to stall for a few second before initializing
and my lord, it takes forever to copy over a simple 20 mb file? I use MS
money and my file is stored on a backup drive on the server. When i access
this file through MS money and do data entry it continuously stalls and
freezes for a few seconds? I never had this problem with my old system?
Makes me question the supposed performance improvement of my upgrade ~~ ! I
have yet to try my 3com in a PCI slot. Would there be any conflicts with the
o/b nic by installing the 3com?
Any info would be a great help.
Cheers,
vwbossBRA@PANTIESgmail.com
(Remove the BRA and PANTIES when replying)
Hi all,
speaker set.
Cheers,
