Need help running 24 gb RAM in a motherboard!
why not go for 144GB on a motherboard
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200302+1071346469+1420247237&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&Subcategory=302&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
though i doubt anything over 12GB would be of much help
also, running crysis and video conversion at same time will more than likely make your cpu bottleneck the GPU before you ran out of memory
Well I'm not gonna go that far, 144 sounds nice n all but that's over kill even for me, and I know you don't know me but trust me when I say that I am captain overkill 😛
But anyways.. The video card point is a very good point indeed, however I plan on running 2 of the new Nvidia Fermi's that are about to be released, and gonna run them at 32x. Sooo, I think that will take care of that one.
Soo.. UPDATE !..
Ok so here is my current rig as of now. I say current because it's ever changing but I'm pretty sure that this is it now...
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb
Sunbeam RHK-EX-SV Rheobus-Extreme 5.25" Bay 4 Channel 30W Fan Controller Panel
Thermalright Venomous X CPU Cooler
Lamptron Noise Dampening Material
1ST PC CORP. PFB1212UHE-F00 120mm Case Fan THIS FAN ROCKS!!
ABS Majesty series MJ1100-M Continuous 1100W
ASRock X58 Extreme LGA 1366 Intel X58 ATX Intel Motherboard
Intel Core i7-920 Bloomfield 2.66GHz
Mushkin Enhanced Blackline 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
ARCTIC COOLING MX-2 Thermal Compound
That's about it, anyone have any suggestions.. lemme know! :)
