Need Help setting up second monitor
rzhang
Commendable
Nov 15, 2016
12
Hello, I have the GTX 1060 ( https://www.amazon.com/EVGA-GeForce-Support-Graphics-03G-P4-6162-KR/dp/B01KU2CIIY) and I am trying to attach a second monitor. However, the card only has one output port but the card is supposed to support multiple monitors. How can I set up the second monitor?
I have one already connected via DVI to my graphics card. I am trying to add a second one, which only had VGA and DVI inputs. However, my card only has a DVI port. I plugged the second monitor into the motherboard with a VGA cable but it says undetected.
How do I attach the second monitor to the card? The card only has one 1 DVI slot
But there is only 1 port. How do i connect 2 cables to it?
isnt it HDMI to DVI? because the card has an HDMi port while the monitor has the DVI port
