NEED HELP! system keeps freezing!
jamesanyoung
222
6
18,715
Specs are:
Intel Core i7-3820 3.6GHz
64 bit Quad-Core Processor
Memory
16GB DDR3 1333
Hard Drive
2TB SATA III 6.0Gb/s 7200RPM
Graphics
AMD Radeon HD 7850 2GB
600W xtreme gear
Windows 8 64-Bit
Raidmax Vampire Full Tower
120mm Liquid Cooling System
Asus P9X79 LE (Intel X79 Chipset)
This machine has started to run TERRIBLY SLOWLY after 1 month of use. I cant say that it is freezing, because the mouse still moves around, but nothing will load for 30 minutes to hours.
Even after i do a restart or manual shut down, the system will boot up, and then start running super slow.
Any advice?
check your RAM usage .
A rogue program may be holding on to RAM instead of releasing it .
Have you installled the mb drivers? , have you tried a fresh install of windows?
jamesanyoung
222
6
18,715
I have not installed MB drivers - i didnt do anything to the system after I got it. I will try that.
Any reason to update bios?
