Hey guys,
how are you?
I need help to build a new machine for video editing and live streaming.
It would be paid by the company, so the requirement is to configure the system with CyberPower through costco:
costco.cyberpowerpc.com
Approximate Purchase Date: this week
Budget Range: $1700
System Usage from Most to Least Important: Video Editing / Live Streaming
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts:
Parts Preferences: by brand or type (e.g.: I would like to upgrade to Intel CPU)
Overclocking: Whatever you suggest
SLI or Crossfire: Whatever you suggest
Your Monitor Resolution: 2k would be enough
Additional Comments: Don't care about the noise, the size or the lights, just need to get the most powerful for the budget.
The main software that I'll be using is Adobe Premiere / After Effects and audition.
But also I may use 3D Max or Maya.
Memory: My understanding is that 32GB would be great, but I think that 64GB might be overkilling.
Storage: I was thinking a fast SSD as principal drive, may be 500gb and a 1TB as a secondary drive.
So, this is my current configuration, please feel free to make any necessary changes:
*BASE_PRICE: [+930]
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+5]
CAS: CyberPowerPC AMETHYST 240V Mid-Tower Gaming Case w/ Front & both Side Tempered Glass + 3x ARGB FANS [-6] (White Color)
CC: Avermedia GC570 Live Gamer HD 2 PCIe High Definition 1080p Capture and Streaming Hardware Encoder Card [+207]
COOLANT: None
CPU: AMD Ryzen 9 3900 3.1GHz [4.3GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 65W Processor [+194]
CS_FAN: Default case fans
EVGA_POWER: None
FAN: Asetek 650LS 120mm Liquid CPU Cooling System w/ Gen 6 Pump & Copper Cold Plate - Extreme Performance (Single Standard 120MM Fan)
FREEBIE_CU: None
FREEBIE_SSD: None
HDD: 500GB WD Black™ SN750 Series PCIe NVMe M.2 SSD - Seq R/W: Up to 3470/2600 MB/s, Rnd R/W up to 220/380k [+40] (Single Drive)
HDD2: 1TB WD Blue Series SATA-III 6 GB/s SSD - Seq R/W: Up to 545/525 MB/s, Rnd R/W up to 100/80k [+125] (Single Drive)
HEADSET: None
IUSB: Built-in USB Ports (Based on motherboard and case selection)
KEYBOARD: CyberpowerPC Multimedia USB Gaming Keyboard
MEMORY: 32GB (16GBx2) DDR4/3000MHz Dual Channel Memory [+120] (ADATA XPG Z1)
MICROPHONE: None
MONITOR: None
MOTHERBOARD: ASUS PRIME B550-PLUS ATX w/ RGB, GbT LAN, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
MOUSE: CYBERPOWERPC Gaming Mouse
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition)
POWER SUPPLY: 600 Watts - Standard 600Watts 80 Plus Gold high-efficient Power Supply
PRO WIRING: None
PROMOSALE1: CyberPowerPC FPS Gaming Mouse Pad [+0]
SERVICE: 2 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
SLI_BRIDGE: None
SOUND: HIGH DEFINITION ONBOARD 7.1 AUDIO
SPEAKERS: None
USBHD: None
VIDEO: AMD Radeon RX 570 4GB GDDR5 Video Card (Single Card)
WARRANTY: STANDARD WARRANTY: 2 Year Parts WARRANTY
WNC: None
_PRICE: (+1615)
how are you?
Costco
Best High Performance Gaming PC - Specialize in Gaming Computers and Custom PC. Award Winning Custom Built Desktops and Gaming Laptops for over 14 years.
Budget Range: $1700
Costco
*BASE_PRICE: [+930]
COOLANT: None
EVGA_POWER: None
FREEBIE_CU: None
FREEBIE_SSD: None
HEADSET: None
MICROPHONE: None
MONITOR: None
PRO WIRING: None
SLI_BRIDGE: None
SPEAKERS: None
USBHD: None
WNC: None
_PRICE: (+1615)
