Question need help to choose case for my gaming pc
May 14, 2019
hi friends
i need some help for choosing case for my pc i have ordered this components
Processor: Intel Core i7-5960X CPU (HASWELL-E) @ 3.00GHz (8 core, 16 thread)
-Liquid CPU cooler : Hydro Series H115i (280 mm radiator)
-RAM : 64 gb Corsair dominator platinum 3200MHZ (16 gb x 4 )
-graphic card : EVGA NVIDIA GeForce GTX 1080 (Founders Edition)
-Mother Board : ASUS RAMPAGE V EXTREME MOTHERBOARD
-CORSAIR AX1500i power supply
which case should i chose -Corsair Graphite Series 780T Full Tower PC case or Corsair Carbide Series CC-9011050-WW Mid-Tower Steel Gaming Case with Red LED (Black)
i just wanted to know this components does fits in mind tower ?
hi friends
Your motherboard is an e-atx motherboard, it is larger than most, it will not fit in a mid-tower case, in which I would recommend theCorsair Graphite Series 780T Full Tower PC case. Although if you could find a regular atx motherboard, that would be good because the full tower cases are pretty big.
Reactions: cyberpunk01
Hi cyberpunk01,
May I suggest purchasing an E-ATX case?
I suggest the Rosewill Blackhawk Ultra case & it's $335 on eBay.
It comes with a SHIT ton of room and 8 fans. You can also add additional fans, there are also hubs for the extra fans in the case. I have it and it's so nice and durable. No idea what your budget is or if you want a case for aesthetics but I'd suggest looking at it. There will be a lot of room for you to operate in.
