Build Advice Need help to choose config ( i5-13600K 1000-1200$) ?
Apr 4, 2023
Hi. Need your advice. Not for games so without graphics card. What can I make better? (I need a case that isn't too big so I can carry it on an airplane):
  1. Intel Core i5-13600K
  2. Arctic Liquid Freezer II 240 https://www.arctic.de/en/Liquid-Freezer-II-240/ACFRE00046B
  3. 1Tb SSD Kingston KC3000 https://www.kingston.com/en/ssd/kc3000-nvme-m2-solid-state-drive
  4. Jonsbo D30 https://www.jonsbo.com/en/products/D30.html
  5. Gigabyte Z690M Aorus Elite AX DDR4 (rev. 1.0) https://www.gigabyte.com/Motherboard/Z690M-AORUS-ELITE-AX-DDR4-rev-1x/sp#sp
  6. Kingston FURY Renegade [KF436C18RBK2/64] 64GB https://www.kingston.com/en/memory/gaming/kingston-fury-renegade-ddr4-memory?speed=3600mt/s&total (kit) capacity=64gb&kit=kit of 2&dram density=16gbit
  7. already have ASUS ROG STRIX 650G 90YE00A1-B0NA00 650W https://rog.asus.com/power-supply-units/rog-strix/rog-strix-650g-model/
Looks fine.
What are you doing with this machine?
What about something half the size, like the Fractal Design Ridge (or similar)?
The Ryzen 7000 series have a (weak) IGP also. Consume less power/heat.
Hi. Need your advice. Not for games so without graphics. What can I make better? (I need a case that isn't too big so I can carry it on an airplane):
What are you going to be using this PC for primarily? What is the reason for not getting a laptop in a similar price point if yo want to bring it on planes and what not? Maybe something like this would be good.
PCPartPicker Part List
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor ($249.98 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($40.90 @ Amazon)
Motherboard: MSI MPG B760I EDGE WIFI DDR4 Mini ITX LGA1700 Motherboard ($199.99 @ B&H)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($63.99 @ Newegg)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($59.99 @ Western Digital)
Case: Lian Li TU150 Mini ITX Desktop Case ($124.99)
Case: Cooler Master MasterBox NR200 Mini ITX Desktop Case ($104.99 @ Amazon)
Power Supply: SeaSonic FOCUS SGX 500 W 80+ Gold Certified Fully Modular SFX Power Supply ($125.98 @ Newegg)
Total: $865.82
Generated by PCPartPicker 2023-04-04 13:16 EDT-0400
Purpose - for comfort work. I have ultrabook for travelling. But I can relocate 1-2 times per year. But anyway what notebook can u advise with the similar power?
miniITX is a compromise with all that it implies that I dont want)
I'd wonder about liquid cooling
What can be optimal choice with water?
What compromise exactly?
Cost & lower power
What is your plan so far as a screen? Keyboard and mouse?
logitech MX Master 3 + K380
Samsung CJ791 + will buy 2d
May be like this ?
  1. i7-13700
  2. Liquid Freezer II 240
  4. Jonsbo D30
  5. MSI MAG B760M MORTAR WIFI DDR4
  6. Kingston FURY Renegade [KF436C18RBK2/64] 64 ГБ
  7. ASUS ROG STRIX 650G 90YE00A1-B0NA00 650W
  8. 2*coolers №1 14x14см Arctic Cooling P14 Black (ACFAN00123A)
if you want to build in a smaller enclosure than the D30, u would have to get a new SFX PSU. something like this:
CPU: Intel Core i7-13700KF 3.4 GHz 16-Core Processor ($391.99 @ Amazon)
CPU Cooler: be quiet! Pure Loop 240 Liquid CPU Cooler ($94.90 @ Amazon)
Motherboard: ASRock Z690M-ITX/ax Mini ITX LGA1700 Motherboard ($139.99 @ Newegg)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($65.98 @ Amazon)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($59.99 @ Newegg)
Case: Lian Li A4-H20 X4 Mini ITX Desktop Case ($154.99 @ Newegg Sellers)
Power Supply: Cooler Master V750 SFX GOLD 750 W 80+ Gold Certified Fully Modular SFX Power Supply ($104.99 @ Newegg)
Total: $1012.83
Generated by PCPartPicker 2023-04-05 06:46 EDT-0400
The Z690 itx mobo has USB bios flashback.
