Hi guys,
Finally I have built my game rig (At last!!). Now I want to overclock the system to get the most out of it.
My computer is using the following parts:
Opteron 165
Corsair XMS Twins (2 x 1 GB) 3200C2
Asus AN8-E
I start with BIOS setting reference:
RAM setting is manually set to 2.5-3-3-6 (manufacturer recommanded values), voltage 2.75., Memclock index value = 400MHz (no idea what this is, but the BIOS auto default is 200MHz and with that my sytem crawl).
CPU setting manually set to 200MHz x 9, core voltage = 1.376V, temperature at idle is 36C
Without changing other settings, I managed to raise the clock from 200 to 220Mhz with no problem (230 will cause random hanging). If I increase that further to 240 MHz, Windows gets very unstable.
Now, by just using the stock heatsink and without increasing the core voltage (I want to do that as a last resource, the CPU temperature shown is already high enough), what else should I tweak in the BIOS? I haven't done anything changes to the RAM settings yet, how should I change them?
I am such a noob in overclocking the modern computer. My last experience in OC is my celetron 300A.
Cheers,
Alex
Opteron 165
Asus AN8-E
Cheers,
Alex
