[SOLVED] Need Help Undervolting 10600k desktop CPU
Rokie34Onli
6
CPU - 10600K
MBOARD - MSI MAG B460 Mortar WIFI
GPU - gigabyte RTX 3060 12 GB NON LHR
Ram - CORSAIR Value Select 8GB 2400 MHz
PSU - Cool Master 650 Watt
CPU COOLER - HYPER 212 EVO
Idle temps are 40c 42c
How to undervolt my CPU its reaching 80 peak and hovering on 72 when i play RED DEAD 2
and temperature of my area is 40c
What is the problem you are trying to solve?
Idle temperatures of 40c -42c. are normal.
What do you mean by temperature in your area is 42c(104f)?
If that is your room temperature, it is unlikely that the idle cpu temperature is anywhere near 40c. Usually it will be 10-15c. higher.
Then, a peak of 80c. is no problem.
Instead of fiddling with voltages and unknown side effects, you can try reducing the max performance in windows power options from 100% to perhaps 95%
CPU - 10600K
What is Ur BIOS version
Reactions: Rokie34Onli
