i plan to upgrade my
(MSI gtx 650 ti boost 1Gb 192-bit gddr5
(1006mhz core clock oced to 1100mhz)
(1253mhz memory clock oced to 1350mhz) - 5012mhz to 5400mhz oced
PF: 27 Gpixel/s TF: 70 Gpixel/s Bandwidth: 130 GB/s
70 degrees celsius max temp while playing crysis 3 on ultra high texture with high presets at x16 AF and SMAAx1 Low AA with motion blur deactivated and lens flare activated at 1680x1050 resolution)
to a better graphics card
would you suggest something that will be compatible with my PSU
http://i132.photobucket.com/albums/q21/kaihuzai/powerstationnf450w1_zps401ab865.jpg
if ever it is compatible with my PSU will it be a decent upgrade over my old gpu??
i play at 1680x1050 resolution.
thanks
thanks
