I am thinking bout upgrading my current amd64x2 4800 @2.5. All i play is games and i think it is really killing me in new games. I just bc2 and it plays it like crap. Here are my current system specs.
amd64x2 4800
2x1gb ocz ddr2 800
windows vista
visiontek ati 3870 512mb
I am on a really tight budget so price/performace is a must. I have a hp desktop that i have to work off of so i have to get a new mobo as well.
I only play at 1280x1024 res for right now(not going to get bigger monitor just yet)
I think at that res my 3870 should do pretty well for a little bit. My HP case only supports a matx mobo so if you could help me pick out a good mobo with decent overclocking options that would be awesome.
My options that I picked out are as follows. Please let me know what you think would be the best option as far as gaming goes with bc2, ac2, mw2, etc.
Phenom II x2 555 BE
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846
There is also the 550 BE(older model) for $15 cheaper (OEM)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704
Obviously the BE would be lot easier to overclock and the ability to maybe unlock the other 2 cores is a plus.
Sorry for the long post any help would be appreciated. By the way my budget would prob be around $300 for the mobo, cpu, and pro ddr3 ram
amd64x2 4800
2x1gb ocz ddr2 800
windows vista
Phenom II x2 555 BE
