Question Need help which path to take
john3182
Commendable
Nov 11, 2022
9
Hi
My daughter wonts a pc and I found a old CPU mobo specs off the old machine is
i5 6600k
gtx970
gigabyte ga z170mx-gameing 5
crosiair cx 600 psu
She plays overwatch 2, fornite /roadblocks ,GTA5/ sims 4/FIFA / resident evil vilage / over watch few other games
was thinking off upgrading mine to give to her
My setup is Ryzen 3600
16 B450-A PRO MAX
16 ram ddr4. 2x 8gb
2070
I had a thought of getting myself a new Ryzen 7 5800X3D / 5800x and new mobo, a 3070/3080 and but the 2070 in her pc or is i5 6600k still going forward
I'm happy to buy 2nd hand parts where I can
Thanks for the help
I'm slightly confused.
i5 6600k
gtx970
corsair cx 600 psu
^ are these the specs to your daughter's current system? If so, how old is the PSU in the build? What ram is her system on, what cooler is the platform on to cool the processor and what case is she working with? Or are they the specs to a second hand system you've found?
On second thoughts, please list the specs to the build(s) like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
for both you and your daughter's builds, being as specific as possible.
I would advise against buying a second hand GPU since they will most definitely would have been used for mining.
hi soory the
i5 6600k
gtx970
corsair cx 600 psu
corsair hydro h100i v2 extreme
no ram
no case as bit missing and bent
psu is about five years old
my
psu is crosair tx 650
Corsair Vengeance LED 16GB (2 x 8GB) DDR4 DRAM 2666MHz C16 Memory Kit- Red LED Lighting
cpu AMD Ryzen 5 3600
motherboard 16 B450-A PRO MAX
geforce gtx 2070
hard drive 1tb samsung 860 qvc
samsung 850 evo 500gb
monitor ROG PG278Q
case msi vampiric o 10 mid tower gaming case
hi soory the
i5 6600k
gtx970
corsair cx 600 psu
no ram
my
geforce gtx 2070
monitor ROG PG278Q
https://www.msi.com/Motherboard/B450-A-PRO-MAX/ <--- if this is the board I don't believe it will support any cpu past a Ryzen 3rd gen.
https://en.wikipedia.org/wiki/List_of_AMD_Ryzen_processors
This cpu would be a decent match with a B550 board.
https://www.amazon.com/AMD-5700X-16-Thread-Unlocked-Processor/dp/B09VCHQHZ6/
AMD Ryzen 7 5700X $234.98
View: https://www.youtube.com/watch?v=Kr5V1lgctYw
