Build Advice Need help with $1200 AMD Ryzen 5 2600 CAD Workstation
eviltothecore94
13
Hi all,
I currently have a 8yr old pc which struggles to cope up with my work load.
So I decided its time for an upgrade and have put together my list.
Feel free to modify the parts within the budget range.
Currently I am over budget by about $300 because I have included case,External Storage,etc.
These are optional so feel free to remove those.
My main usage will be cad modelling and analysis using NX CAD and hypermesh with max of 100 parts per assembly.
I have added GTX 1660Ti as preferred graphics card but I also want to add Radeon pro W4100 for CAD.
But I will be using only one monitor can I switch the hdmi cable between the graphics or can I plug in two cables from different cards to the same monitor?
Will this rig be able to cope up with my work load?
I might want to game once in a while. Nothing to hard like ultra setting etc. Must be playable with smoothly.
I have played GTA 4,crysis 2 back in 2012 with medium settings. So thats not an issue.
PCPartPicker Part List
Type|Item|Price
CPU | AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor | ₹17748.00 @ Amazon India
CPU Cooler | Cooler Master - Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler | ₹2947.00 @ Amazon India
Motherboard | Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard | ₹12688.00 @ Amazon India
Memory | Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory | ₹11398.00 @ Amazon India
Storage | Samsung - 860 Evo 250 GB M.2-2280 Solid State Drive | ₹4700.00 @ Amazon India
Storage | Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive | ₹5999.00 @ Amazon India
Video Card | Zotac - GeForce GTX 1660 Ti 6 GB GAMING Video Card | ₹25880.00 @ Amazon India
Case | Corsair - Carbide Series 300R Windowed ATX Mid Tower Case | ₹6785.00 @ Amazon India
Power Supply | Corsair - VS 650 W ATX Power Supply | ₹4420.00 @ Amazon India
Monitor | LG - 24MP59G-P 23.8" 1920x1080 75 Hz Monitor | ₹11000.00 @ Amazon India
External Storage | Western Digital - Elements 1 TB External Hard Drive | ₹3985.00 @ Amazon India
| Prices include shipping, taxes, rebates, and discounts |
| Total | ₹107550.00
| Generated by PCPartPicker 2019-05-05 12:32 IST+0530 |
stick with 1 thread
Hi all, I am from India.
I have a 8 yr old Intel Pentium Dual Core PC which cannot cope with the workload so planning on upgrading.
I have put together a config based on my requirements
Feel free to modify list as you please but stay under budget
An Intel equivalent with the same budget is also appreciated.
I have already overshot the budget by about $300
My requirements
The pc must be able to run both Siemens NX and Altair Hypermesh.
The system must be able to work smoothly with assemblies containing 100+ parts.
I would also like to game occasionally. SIngle Player FPS and adventure games (Skyrim,GTA V,Battlefield 1,etc) at reasonable fps
I currently have a 1024X768 monitor and I am planning to upgrade to a 24 inch monitor.
Now comes my main concern.
I have included GTX 1660 TI but I also need a Radeon Pro W4100. Since I have only one monitor can i connect both cards to the same monitor?
Will it work as required based on the use case or will there be any problems?. I never had a graphics card in my pc till date so I need some advice
in that area.
PS
I created the same thread today morning. But it has disappeared for some unknown reason. I am not sure whether I have made any mistakes.
Type|Item|Price
| Total | ₹107550.00
| Generated by PCPartPicker 2019-05-05 15:31 IST+0530 |
