Need help with bios settings...
Blitz Blitz
753
23
19,015
Hi. I searched a lot of info in web, but not found some things with bios settings. What is overspeed protection? Should I enable or disable it with non overclockable cpu? What to do with power states? There is a lot of opinions that should be disabled, other side says it should be enabled and don't efect with newer systems. I talk about eup 2013, c1e support, intel c-state, package c state limit.
Thanks. And sorry for english.
overspeed protection will roll it back to stock settings on a failed overclock, usually tries to boot 3 times and if it doesn't boot it goes back to stock settings.
I leave the c states on, I like my cpu to throttle down when not in use. People disable to seek the max overclock as the throttle down and lower voltage can cause a freeze or crash if it does not ramp correctly when demand increases using more MHz and voltage.
