Question Need Help With BSOD! please <:L
steelseeker
25
hello, so over the past 4 months i been on and off blue screening and did some tests thinking it was becase of ram. i replaced my name with new ram and still keep having the same issues, i have also did a clean install of windows 10 on my ssd to see if that fixs the issue it keeps happening when am in games like path of exile and ark.
i have tryed googling the errors and done what all have said. new ram clean install disable drivers update ect, my system besides the blue screens seem to be ruining normally but randomly blue screen when playing games. some time just useing firefox.
i have i5-9600k 3.7hz
ddr4 3600hz ram
2070 super gtx
tb ssd for C drive
all my parts are like 1 year old or 2.
and 1 ssd for games and normal harddrive for stuff :l
here are 2 of my recent crashs, did a fresh clean in stall 1 week ago didnt play much games so didnt blue screen. then started and it happend
the old ram i had a i did a ram test that boots from flash drive and it had 50 errors so i asumed i had bad ram.
Here's the results from the last 2 dumps you posted: https://jsfiddle.net/e7sc2jw4/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:010222-9078-01.dmp (Jan 2 2022 - 01:21:03)
Bugcheck:DRIVER_VERIFIER_DETECTED_VIOLATION (C4)
Driver warnings:*** WARNING: Unable to verify timestamp for RzDev_0084.sys
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 06 Sec(s)
File information:010122-9468-01.dmp (Jan 1 2022 - 19:49:17)
Bugcheck:SYSTEM_SERVICE_EXCEPTION (3B)
Driver warnings:*** WARNING: Unable to verify timestamp for nvlddmkm.sys
Probably caused by:memory_corruption (Process: PresentMon_x64.exe)
Uptime:1 Day(s), 0 Hour(s), 02 Min(s), and 36 Sec(s)
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
i was going to ask how old your Razer stuff was as
Jul 26 2008Razer Synapse Service.sysRazer Synapse driver
seems old to me. I was going to suggest an update as even the newest Razer drivers you had are from 2020
this could be a problem too
Nov 02 2017cfosspeed6.syscFosSpeed driver (cFos Software)
its used for speeding up internet.
that is based on the last dumps Gardenman converted, I don't have results for your latest ones.
the drivers should be fairy new for razer, it was clean install from site the same day i installed windows 10 a week or 2 ago, and as for cfoss its apart of my mother bored install drivers i uninstalled it now tho,
so other the last day i left a game open with max settings trying to see if a blue screend had it open for 14+ hours no blue screen, i think xmp disabled or removing razer drivers fixed my issue? not 100% sure but i need razer installed so will do more testing /playing with razer reinstalled XD ty for help and time, sorry for wall of text
Reactions: Colif
Driver verifier blames Razer drivers
but not the one I asked about
Aug 17 2020RzDev_0084.sysRazer driver
seems it decided to stick around since I don't see the others there
System Service exception blames Nvidia drivers
try running DDU again but instead of getting drivers from Nvidia, run windows update after the restart and let it find drivers for card. They still from Nvidia, just a little older and maybe more stable.
If you keep getting errors in different drivers, you might want to check ram again with that program you mentioned on USB just to make sure its okay. Bad ram can make good drivers act bad.
Reactions: steelseeker
okay well do, havnt had any blue screens in the past 28ish hours, only thing i changed was xmp on bios and reinstalled fresh razer driver for mouse/key bored. if i get another blue screen will test ram, and do DDU and windows thing
