Need Help with Build Quick!!
neurox
18
I am going to purchase a pc later today, but just went on newegg, and found a really good combo with a good discount. Here is my entire build, and there are 2 psu's and cases because the -$59.99 one is the combo i might get. Please help me choose based on if it is better, and please make sure it is compatable.
df6fb0987673a459e01522ee2a1ce730
if you cant see the image here is the link:
http://gyazo.com/df6fb0987673a459e01522ee2a1ce730
Neither PSU is really acceptable.
Here is one case+PSU combo I can recommend:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.693976
The 550ti is not a good buy usually. Radeon 5770/6770 is the better buy at that price range.
Ref: http://www.tomshardware.com/reviews/gaming-performance-radeon-geforce,2997-3.html
If this is a gaming build, you should probably re-adjust things so that you are a bit more balanced. Money is better spent towards a GPU. Perhaps an i3?
Here is one idea:
SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Rosewill Green Series RG530-S12 530W Continuous @40°C, 80 PLUS Certified, Single 12V Rail, Active PFC "Compatible with Core ...
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ...
ASRock Z68 PRO3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor BX80623I32100
TOTAL: $753.40
