Need help with building new business pc please
Ref2365
33
I am looking to build a business pc, the pc would be used strictly for data , some still images and internet sales, I like to do multi-tasking with the pc’s so I normally have 6 or 7 windows open in same time, I like to get Intel cpu, either i3 or i5, as for ram 8 or 12 gig for the video I like to have a 500 gig, and for hard drive I was thinking of getting 2 one 250 gig for the operating system and 1 terabyte for the data and such, my budget is between 800-1000.
I do appreciate any and all help.
Thanks
Jon
Hi Ref2365 (or Jon). If your looking for a system build, rather than specific help with CPU & Components, you would be better off posting in the Systems section of the forum. Or you could request for a mod to move the post.
Make sure you fill out the form in one of the stickies at the top of the forum section, and I'm sure you will get the help you need.
I am looking to build a business pc, the pc would be used strictly for data , some still images and internet sales, I like to do multi-tasking with the pc’s so I normally have 6 or 7 windows open in same time, I like to get Intel cpu, either i3 or i5, as for ram 8 or 12 gig for the video I like to have a 500 gig, and for hard drive I was thinking of getting 2 one 250 gig for the operating system and 1 terabyte for the data and such, my budget is between $800-$1000.
Thanks
Jon
Hi Jon, welcome to the forums.
Let's talk over some stuff real quick.
-First off, we can easily get that i3 you want. The i3-2100 fits the bill perfectly.
-You do not need 12 GB of ram. Trust me on this one. In fact, you only need 2 GB. However, we'll throw in 4GB just to be sure that you won't run into ram related issues.
-How about an SSD for the OS, (60 GB, allows you to install windows 7 plus some apps, like MS office and such) and 1 or 2 TB for data? SSD's are WAY faster than mechanical hard drives. However, they cost much more.
Last thing is, what do you have now? Do you need a monitor? How about mouse, keyboard, or OS?
I'll get back to you once you answer those questions.
I would start by finding a couple of cheap 23 or 24 inch monitors, that will leave you with a budget of around 750, which is more than you will need. I'd say around $600 should get you what you the rest of what you want. If you post the build for $1000 max, most of the builds will come in around $1020. If you order the monitors right away, then post a $600 build, that will be more than sufficient for what you need. Also , you'll want to compare Win 7 Home premium and Win 7 Pro to see if you need any features from pro, there is a decent price difference between the two.
Thought I would throw this build out there to give you an idea of what you could get with your budget. I already had it done up for a consulting gig for a small business on a hardware budget of $1000 and $350 for software. It is designed for a small business they wanted to have multiple windows open on dual monitors as well an SSD boot drive and TB of secondary storage. I removed the Software and Keyboard/Mouse as they were "bulk" items.
Case and Power Supply
Antec NSK 4482B Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 380W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129072
Item #: N82E16811129072
-$10.00 Instant
$99.99
$89.99
Secondary Storage Drive
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Item #: N82E16822152185
$64.99
21.5" Monitors x 2
HANNspree By Hanns-G HF225DPB Black 21.5" Full HD WideScreen LCD Monitor w/Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824262011
Item #: N82E16824262011
-$30.00 Instant
$319.98
$259.98 ($129.99 each x 2)
Dual Monitor Stand
Planar 997-5253-00 Black Dual Monitor Stand for LCD Displays
http://www.newegg.com/Product/Product.aspx?Item=N82E16824995006
Item #: N82E16824995006
-$20.00 Instant
$149.99
$129.99
Dual DVI head video card
EVGA 01G-P3-1431-KR GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130609
Item #: N82E16814130609
$20.00 Mail-in Rebate Card
$74.99
RAM
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) F3-10600CL9D-4GBNS
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231394
Item #: N82E16820231394
$38.99
Motherboard
ASUS P8H61-M LE/CSM (REV 3.0) LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131724
Item #: N82E16813131724
-$5.00 Instant
$79.99
$74.99
CPU
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor BX80623I32100
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
Item #: N82E16819115078
$124.99
Primary Boot Drive (SSD) for OS and Office Suite
SAMSUNG 470 Series MZ-5PA064/US 2.5" 64GB SATA II Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147062
Item #: N82E16820147062
-$15.00 Instant
$124.99
$109.9
-$30.00 Instant
$149.99
$119.99
$968.90
