Hey guys. I'll get straight to the point. (Device: Dell G15 5510, i5, 2 x 8GB RAM, GTX 1650)
I have been getting random crashes and BSODs on my laptop. Most of them indicate memory failure or hypervisor related issues (I use WSL). It works fine for hours and days but then it will randomly either just freeze or blue screen. I just ran memtest (currently running on that device) and on Pass 2, it has returned 821 errors. Currently testing with both cause I wanted to see if RAM was faulty to begin with. (I ran it once a few months ago and upto Pass 3/4 it returned 0 errors. I closed it after a while). Although I will now check the RAMs one by one, I want to know whether a faulty RAM slot could cause this issue. If that is the case, will I have to use the RAM that shows 0 errors (assuming one of two is fine) on both RAM slots to see which one is faulty? The PC works fine for 2-3 days and I face this error so I am not sure if a faulty RAM slot is to blame.
Also, if I am testing a single RAM stick, is there a particular slot I need to use to test it? My friend mentioned something but I don't recall and I can't find the answer online either.
Current errors shown:
