Question Need help with dimensions of AIO
Jun 23, 2019
Hi!
I'm planning on buying the Cooler Master ML360R AIO Cooler for my Ryzen 5 2600, which is 39.4cm in height, while my Front in around the 40cm.
I do have 3 stock fans of 120mm each, but not sure if the AIO will fit in my case.
Should I take the risk and buy it (can't return, buying abroad) or go safe with the ML240R?
My case is the Sharkoon TG4, which barely has any info about him online, so having a hard time figuring this one out.
Thanks in advance!
According to this review, a 360 in the front wont fit due to the screw hole placements+the (reservoir)end tank for the AIO. You're going to need to change the AIO to an air cooler or change the case to something that will accept a 360 in the front or top.
