I own a gigabyte gtx 660 that i bought in 2012. i have been using it till now but have swapped out the rest of the components in my pc.
Here is my current specs
CPU: i5 600 with coolermaster hyper 212x fan
Ram: 8gb hyperx
motherboard: msi b150 pc mate
PSU: corsair cx600.
this current setup was running without problems till mid 2017 and thats when the problems started.
i was running this on windows 7 ultimate and the display would freeze when starting games or playing video files or even photos for the first time after boot. sometimes it would stay frozen and i would have to restart the pc. other times (about 50%) the display would black out and resume like normal and i was able to play games or movies like normal. in these instances i would get the error message "Display driver stopped responding and has recovered".
somedays it would be worse than usual needing upto 5-6 restarts before it would recover. other times (rarely) it would freeze again even after it had recovered once.
i then changed over to windows 10 in 2020 and everything was fine till now. no crashes no freezes just worked perfectly.
but now these past 3 weeks i am unable to start any game in my pc. some games would just crash without any error message (rocket leaue) and other games gave a directx11 stopped or hung message. " DX11: DXGI_ERROR_DEVICE_HUNG"
the pc is usable rn to play movies but cant play games.
on using photoshop or illustrator if the load gets a bit high the application freezes with this message "Application has been blocked from accessing graphics hardware".
on a side note the gpu fan used to get a bit loud in the past when gaming or at high loads.
Is my GPU failing or is it some other problem? My windows is upto date and so is my graphic drivers. should i reinstall windows
any help would be greatly appreciated
Ram: 8gb hyperx
PSU: corsair cx600.
