So I am about to order the components for my new built. Among other components there will be the Gigabyte GA-P67A-UD4-B3, LGA1155 motherboard, i5 2500K and the 560Ti GPU. It's all going to be packed inside the NZXT M59 case. The case comes with two 120mm fans out of the box (one fan has LEDs and is mounted at the side, the other one is the rear exhaust).
Now I would like to know if that's sufficient cooling for such rig or should I reposition one fan from the side to the front or maybe get some more fans. The mobo supports only 2 system fans so I would need to know a way to connect more than two fans to it in order to have better cooling performance.
Any help would be great!
That's the link to the official M59's specs: http://www.nzxt.com/new/products/classic_series/m59
