[SOLVED] Need Help With Figuring Out Dimensions
You shouldn't but from that cases layout, I'd advise having the AIO mounted to the front of the case so you can intake fresh, cooler ambient air to help keep the temps on the CPU better.
In that case, I might as well just go with the 360mm radiator version. Just sucks because I want the fans in front to be showing in the front of the case.
I found a non clear front panel version of the same case, now my focus will be using a 360mm radiator on it and making sure the spectacle is contained in just the internals, with no front panel show. I think I'm okay with this.
