Need Help with Freezing Computer
bhk7594
69
My Specs:
OCZ OCZ2N800SR4GK 4gb (2 Stick) SLI ready RAM
Apevia X-Jupiter Jr. Case
(Quad-Core)Intel(R) Core(TM) 2 Quad Q9400 @ 2.66GHz 1333FSB 6MB L2 Cache 64-bit
EVGA 750 SLI NVIDIA 750i SLI Chipset LGA775 Supports LGA775 FSB1333 DDR2/800 Mainboard w/GbLAN,USB2.0,&7.1Audio
635 Watts Power Supplies Sigma Shark SP-635W PSU
9800 gtx
Alright so I have had problems with freezing since I purchased my computer in 2008. The computer would freeze mid game but only during gameplay and usually about 10-20 min in. This was when I had 2 9400 gt in SLI. Then I called the company that built my computer and they sent me a new motherboard. I replaced the motherboard but after that I got a ps3 and stopped gaming on my PC.
Recently I got myself a 9800 gtx and upgraded to Windows 7 Ultimate. Now during gameplay the computer will freeze. By freeze I mean I need to hardboot to get the computer to run again. The mouse and keyboard wont work and the game will freeze on the fame its at.
Now I have tried a bunch of things:
- First things pointed to heat issues because my computer runs a little hot (60 c on GPU in game and 50 c on cpu in game) I cleaned out the case and all of the dust and got the temp to drop about 2 c This did not fix the problem
- Second I tested the GPU thinking it was a faulty card using 3d mark. Came back fine so that knocks out the GPU
- Third I tested the RAM first with testing program then by popping one stick out playing until it froze and then trying the other. The computer froze with either one in knocking out the ram.
- I had to replace the motherboard so that knocks out the motherboard
Recently a new problem has arose. When the computer is in sleep mode for an extended period of time I will have to hardboot to get the computer to work. Sometimes it resumes windows and sometimes i need to hardboot twice to get the option to delete the resortation data. I am not sure if these two problems are related.
Any help would be great
Don't go by watts when buying a power supply. Look at the amperage. Get something with 52-60 amps minimum and make sure it has enough connectors to get the job done.
The evga/xfx...etc. motherboards are known to be heat mongers. Regardless of what temps you are reading I bet in reality they are higher.
The video card/s would be my first thought. Next thing I would do is to pull the heatsink, ( processor + video ) scrape off whatever thermal material is there and reapply paste. Do this with the board out so you can get the heat sink hold downs to seat properly.
Next thing would be to remove the heat pipe system and scrape off that hard crap they use for themal paste and put whatever you're using on the processor heat sink. It'll take time to get this stuff off but it's worth it in the long run. All too often it's not applied right and sometimes it misses the chip underneath and sits off to the side.... doing nothing.
Raidur
2,365
Memtest86 will run either until you stop it or the PC freezes from instability. Default settings should be fine. Let it go for a good couple hours to be sure your ram is stable. (usually unstable ram will show it in the first few minutes)
bhk7594
69
Yea I am building a new computer in Sep. so I will go and buy a power supply that I can use in my new computer.
Probably something around 800 watt. Hopefully that will solve my problems.
I will updated tonight after I hook up new PSU!
That's a nice PSU. If they don't have that one, be sure to look for one from a known quality manufacturer. I already posted what I think you should look for in a quality PSU. I also posted some known quality manufacturer's.
The OCZ unit satisfies all these conditions. It has active PFC, is 80 Plus Gold certified (the best efficiency you can currently get), and puts out 71A on the 12v rail. It also has a 5-year warranty.
bhk7594
69
No just wanted to make sure it was not overpriced I am getting this one so I can use it with my new build in a few months. Should be fine. Thanks for your help will update tonight.
N.Broekhuijsen
3,098
may I be honest:
Yes, a very high end PSU is a good thing, but you don't really need it.
from what you had, "It's not hard to improve on garbage"
anything from cheaper companies is plenty good. As long as it's 80 plus certified it should do the job just fine. just make sure it's a well known manufacturer, and that it has enough watts.
There's a whole lot more to a quality PSU than being 80 Plus certified and a wattage rating. What's most important is active PFC and the Amp output on the 12v rail. The wattage rating on cheap PSU's doesn't mean anything because they output most of their power on the 3.3v and 5v rails.
bhk7594
69
Just compared the new one to the old one and the old one had 2 12v rails at 20A and the new one has 1 12v rail at 71A not sure what that means but its a large numerical improvement
